Old 01-03-2016, 07:27 PM   #436
jaykay
jaykay's Avatar
This is the general location of the X-51/EBS baffle (excuse my poor graphic skills,but you get the general idea).
As you can see, the oil returns (both the Boxster stock returns and the 997 returns) discharge "outside" of the vertical baffle. With the horizontal windage tray installed, the oil discharges on top of the tray. Thus, return oil has to flow back thru the doors of the baffle to refill the sump.
Your graphic is good. This was what I was thinking I could see. Soooo when I did this I made sure that I had the old style swirl pots with big holes for them to protrude through where by the discharge was under the tray in the trapped volume with the pickup. This is a long time ago....I believe I thought this to be the best arrangment at the time. Return oil is feed directly into the trapped vol where the pick up sits.
I fail to see how the 997 returns are better returning oil on top??? Perhaps it's a deairation thing??
986 00S
