Old 01-03-2016, 06:44 PM   #3
KevinH1990
KevinH1990's Avatar
I contacted North Hollywood and Palo Alto Speedometer a few years ago when I was installing my 996 cluster. At that time, they said they could not obtain the lcd's for the 986/996 clusters from VDO. Maybe that has changed in the interim.
I think you may be able to de-solder a good lcd from another damaged cluster and re-solder it your cluster. However, I think that may require a special tool.
As you know, I ended up re-programming the circuit board from my 986 cluster and fit it in a damaged 996 cluster: http://986forum.com/forums/general-discussions/43017-carrera-gauge-swap.html
