Old 01-03-2016, 10:06 AM   #13
arthrodriver
The switch is probably a simple make/break. If you can see the +12v and return terminals remove the wires and use a little lite, your DMV beep function or volt setting and observe when working the switch. I had a switch with an adjustment arm...serrated so it could be set for the pedal deflection. Lay on your back and take a look. I had apparently accidentally hit that arm while replacing the slave master.
arthrodriver is offline   Reply With Quote
