Old 01-01-2016, 11:27 AM   #4
Mig
When I replaced the clutch on my '07 Cayman and '99 Boxster I removed the exhaust as one unit by disconnecting it from the exhaust manifolds.
The solution which worked for me was to tap on the tightest fitting socket I could find and then break them off with an impact gun. Take a grinder to the welded nut to remove it.
I replaced the hardware with new nuts and bolts along with a good amount of anti seize compound.
Mig is offline   Reply With Quote
