Old 01-01-2016, 07:19 AM   #10
jdraupp
Originally Posted by barthol View Post
Thanks a lot fro all the feed back,
As I can read from your answers , If I have to do the clutch it is also worth taking a look on the IMS.
As the car now is 150.000 km it is beyond the risk of failing early.
If I exchange it will I then be back at the beginning, having to worry weather the new IMS will fail within a few miles? Or are there solutions out there I can use that will " take the risk " away?
anyone who knows which solution would be the best If I do the exchange .
Actually I would like to get rid of this concern if there is a suitable solution.
BR
Barthol
If you "exchange" the ims, you don't put a Porsche bearing in it. There are many aftermarket options, one of the best is the ln engineering retrofit bearing.
