Originally Posted by 911monty
Change the spark plug on that bad cylinder. It is probable the plug has carbon tracks due to the previous bad coil pack, this will cause the plug to misfire along those carbon tracks. Under hard acceleration the air fuel mix is more dense and harder to ignite, which requires more voltage to jump the plug gap. This increased voltage then travels the carbon tracks. Give this a try.
Perfect. I'll certainly give it a try! I didn't manage to do the plugs as I didn't have a medium extension for the socket set. I only had a long one which is fine for cylinders 2, 3, 5 and 6, but for 1 and 4 it was too long. I didn't want to mix the plugs either as the BERU ones had 4-points on them, and the temporary replacements I have are NKG 3-points. Wasn't sure if you could mix them, so I didn't change them at all.
I've got the extension now so I'll get right on it weather permitting!
Originally Posted by BoxsterSteve
Given the amount of oil gunk there, I'd change the plug tubes and o-rings as well. May have nothing to do with your misfire, but it can't hurt either.
I didn't think the later 3.2 S engines had tubes?
