Old 12-30-2015, 06:50 PM   #8
BoxsterBob - CA
That is a good suggestion, Steve. I have tried bleeding a second time AFTER the pedal has been pulled back off the floor and pumping. I used a 2x4 pressed against the pedal (1 inch from the floor). Reconnected the Motive and pressurized to 22 psi, as soon open the bleeder, the pedal hits the floor and the 2x4 falls. I close the bleeder, disconnect the Motive, pull the pedal off the floor and pump, still not traveling to the floor.
I will try the manual process tomorrow.
BoxsterBob - CA
2014 Boxster S
Previous - 1999 Boxster / 1972 914
BoxsterBob - CA is offline   Reply With Quote
