Old 12-30-2015, 04:28 PM   #11
rick3000
There Is No Substitute.
rick3000's Avatar
Not sure if you have a manual or tiptronic, but if it is a manual, you can use a funnel instead of a pump. I attached 3' of vinyl tubing to the end of a funnel with a heat gun, and poured from the engine bay down into the fill hole. It's a lot easier in my opinion, and cost about $3, but you will need an assistant.
FYI, if you have a manual transmission make sure you use the correct OEM oil. Earlier years use a different oil.
