Old 12-27-2015, 10:47 AM   #11
jaykay
jaykay's Avatar
The horizontal baffle is commonly referred to as a windage tray....as far as I know. Mantis have had this in their set up for long while. I think it is a very key design feature. I have big holes in my Mantis tray for swirl pots. I don't recall having any other holes so the oil is trapped. Return is facilitated via the open centre....I hope this is enough.
Tom will have the larger older style diameter swirl pots....so this is why you see two big holes to allow the pots to go through. I have heard of Caymans going back to this style for more de foam action. You definately want to return oil to the trapped volume underneath where the pick up will be.....otherwise there will be a problem
986 00S
