I got a cheapo pair off Ebay for less than $20 shipped. Worked so-so when I changed out my AOS. Wasn't enough room to get a good bite on the clamp.
But like you, my car was on jack stands and I was on my back when I changed my motor mount and had to move one of the coolant hoses out of the way. Like mentioned above, squeeze the clamp with some channel locks and slide down the hose. And then you might need one of those picking tools (or screw driver) if your hose is stuck on to the pipe. Good luck.
Glen
