Old 12-25-2015, 01:17 PM   #1
Mig
I'm almost done doing the clutch job on my '99 Boxster
Clutch stuff:
- rear main seal
- flywheel
- flywheel bolts
- flywheel pilot bearing (included with the new flywheel)
- clutch
- pressure plate
- pressure plate bolts
- release bearing
- transmission output shaft guide tube (mine came with the new seal installed)
- shift fork
- shift fork ball pin
- shift fork retaining spring
- exhaust flange gaskets (I removed my exhaust as one piece by undoing it from the exhaust manifolds)
- exhaust flange nuts and bolts
- gear oil
While I was in there stuff:
- air/oil separator
- IMS bearing kit from Pelican parts
- 2 timing chain tensioner washers
- 2 camshaft end plugs
- coolant expansion tank
While i was around there stuff:
- spark plug tubes
- spark plugs
- air filter
- cabin air filter
- rear drop links
- clutch slave cylinder
- rear stabilizer bar bushings
- oil filter / drain plug washer
- push rivets for rear spoiler
Mig is offline   Reply With Quote
