Old 12-22-2015, 09:17 PM   #11
dghii
Originally Posted by Maydose View Post
Have just replaced my switch and the headlights worked fine for 3 trips.......aaaaagh .then out again.....will try your pull and push routine. I suspect that the old switch may be OK!
Need to be more specific when you say your headlights are out as the internal wiriing (insulation) in the headlight assembly will degrade and crack, causing lights to fail or work intermittently.
Was your new switch new or from a dismantler?
