Old 12-22-2015, 03:39 AM   #1
mikesz
mikesz's Avatar
I have replaced coolant in my 99 and found the burping method to work just fine. I had similar problem, replaced the coolant cap and make sure its on tight. Also, my engine bay fan was not working. Replaced the fan and no more light. You can check if its working by removing the relay in the trunk and using a wire jumper to test. Replacing is not that difficult one nut and unplug the wires.
99 Porsche Boxster
