Open the pressure vent valve for a few heat cycles - I'll bet you see the coolant level drop if air is in the system.
The valve's D ring needs to be flipped up & is located under the plastic cover between the coolant fill and oil fill caps in the rear boot (trunk).
2001 MV Agusta F4.
