Old 12-21-2015, 10:31 AM   #1
PorscheFan5
Originally Posted by Sassmatt72 View Post
Just looking into this, what year pump are you sourcing??
thanks.
p.s. are you re-using the mounting bracket, upper resivior, is wiring an issue (i.e. do you need the controller module?), did you resue the oem fittings on the pump?
thx
Hi Matt,
I got the PS pump from 2001 MR2 Spyder. I am fabricating the mounting bracker myself, as you saw yesterday...:-). The pump has its own reservoir and I don't think I need another one. There are good articles on the wiring, in fact there is a sticky article. The controller is part of the pump assy. I got the fittings and high pressure hose from Summit racing. Mostly I am using Fragola fittings and hoses. I am getting the rack end fitting from Woody and will see if I can get 6AN tips welded to the ends. Will post pictures on my website's Power Steering section once done. You can check it out here:
boxsterev
PorscheFan5 is offline   Reply With Quote
