Chuck, before connecting anything, I would multimeter across what you describe as the positive connection and the ground connector. Set the multimeter to ohms and read the resistance.
If the reading is zero, the circuit is open / broken.
If you see a resistance value, don't connect to the car yet but connect up to a battery with say a (~15 amp) fused tail and see if the heating element warms up.
At least then you can see if its operational without compromising the cars electrical system.
2001 MV Agusta F4.
