Thread: Smoke bomb
Old 12-16-2015, 04:47 PM   #28
BYprodriver
BYprodriver's Avatar
[QUOTE=alm001;476782]I got back to the car last night and spent a couple hours on it.
I got all the coilpacks and spark plugs out. Here is the plug from Cylinder #1
The cylinder also leaked a bunch of oil out of the plug hole, so it was full up higher than the plug hole by a good amount.
I turned the motor over with all the plugs out, and everything seems fine mechanically.
The AOS vent tube, the intake tubing and the two intake manifolds had an [un]healthy amount of oil in them. I have them and the TB off for cleaning before putting it all back together.
You will have a lot of oil in the intake manifold too.
Hydrolocking the engine can bend connecting rods. I would spin the engine over with the starter alot to dislodge as much oil as possible. Turn engine over by hand to see if you can measure TDC height is same for all cylinders. Never tried this myself but if any of your rods are bent it will eventually break!
