Old 12-16-2015, 01:19 PM   #1
derfo
Cool Rear wheel bearing replacement
Hello guys.
in the middle of replacing rear wheel bearings on 01S.
using the sir tool to remove the hub, the hub came out with the inner race of the bearing still attached to it.
not sure if i did something wrong, or the bearing was so bad that it fall apart.
anyway, I'm on my way now to the local autozone or HF to look for a puller that might help. i noticed two grooves on the hub so i assume some sort of a puller will fit in there.
if you got any ideas how to remove it, it will be appreciated.
thanks in advance.
Meir.
Hello Meir
I just seen your post. One place you could have a look is Pelican Parts. I went to their site and they have it all explained there. They have one photo showing the bearing just how yours is with a two prong puller dragging it off.
derfo is offline   Reply With Quote
