Old 12-15-2015, 03:18 PM   #15
flaps10
flaps10's Avatar
The color of those plastic bits is wrong for the variocam chain ramps, at least for my engine. There are 6 large ramps of blackish plastic and four small ramps that are much lighter color for the variocam.
That bashed sump plate is sad. If there isn't visible damage on the outside then it is likely, as someone pointed out above, from someone jacking the car up by the sump.
I had just a bit more metal in my oil than you're finding, and my pan was clean. I really wanted to click my heels together and do an oil change. Pulled my IMS bearing and it was just starting to flake. I went the rest of the way in and found my main bearings were totally shot.
flaps10 is offline   Reply With Quote
