Thread
ugh...ferrous metal found...
12-15-2015, 11:05 AM
16
Viper10000
Ok, so I finally pulled the oil sump and it looks really good! Just a couple bits of chain ramp material.
However, when I wiped up some of the oil from inside the sump plate, i noticed a few metallic looking specs which turned out to be magnetic...
And I also noticed that there are cracks inside the sump plate, has anyone else ever seen this? and can I still reuse this cover? No leaks before removal...
So, where do I go from here? Is this amount of metal normal? Should I just put this all back together and check again in a few hundred miles?
Viper10000
Find More Posts by Viper10000
