Thread: I'm lost
Old 12-13-2015, 07:30 AM   #12
Luv2Box
Luv2Box's Avatar
Originally Posted by jdraupp View Post
Maybe. Maybe not. The fact that it fires and dies can be a large enough vacuum leak that the motor cannot function. I had this happen when I replaced my starter. I didn't get the intake t back on correctly and created a massive vacuum leak. The result was that the car would fire and immediately die.
Yes that is true as each system has to go through a series of run cycles to throw a code so if it isn't running it probably won't.
Luv2Box is offline   Reply With Quote
