Old 12-12-2015, 07:20 AM   #1
boxster
clutch replacement parts
So I'm about to swap my clutch, and till now I bought the clutch 3 piece kit, flywheel, and new bolts for clutch and flywheel. My mechanic also suggested I get the fork as well, so I went online to order the fork and found much more that could be replaced,including: Flywheel spigot bearing,clutch fork pivot, retaining spring for clutch release,clutch fork retainer clamp,leaf spring for clutch release lever,clutch release lever ball pin,....etc.
So to cut a long story short, does anyone have any experience with a base box clutch replacement, and which other parts i will REALLY need to swap,apart from the 3 piece kit, flywheel and bolts?
boxster is offline   Reply With Quote
