Hmmm...so the same motors that rotate the xenons up when you hit the high-beams are the ones that auto-level the lights in the factory setup? If so it seems that the control unit would simply need a sensor input to enable the auto-leveling?
What we need is someone with the factory Litronic kit take a look and compare it to the aftermarket and see if where the wiring differences are.
Hell if you can build a robot out of Legos it should be possible to get a bloody headlight to auto-level.
