Thread: battery tender
Old 12-11-2015, 11:00 AM   #1
Jimbo409
battery tender
Just hooked up my battery tender and the red light stays on which suggest there is a draw on the battery somewhere.I am wondering if the front trunk has to be pushed all the way down for the light to shut off,is there some kind of button somewhere to make sure the light is off.I am not sure this is what is causing the drain,I will leave the battery tender on overnight and see if that helps and the green light comes on.I do not want to leave the battery tender on with the red light on all the time
also if I remove just the negative cable on the battery to hook up the battery tender will I have any problems with loosing all kinds of set ups.any problems with removing just the negative cable.Thanks Again Jimbo
Jimbo409 is offline   Reply With Quote
