Cool project.
I just bought the conversion kit from renegade but they simply use a Toyota pump like you are doing. Check out my build thread and you will find some info in there.
The easiest thing to do with the fittings is just cut them off of the factory lines and weld new fittings on the end, I never had to worry about dimensions. Or you could just cut the factory hoses and have them crimped onto new lines etc. Either way just cut up the factory stuff, it's the easiest thing to do.
Good luck
J
John or J.J. - But I answer to most anything~
*2000 Honda Accord 4DR V6 - 220K*
http://986forum.com/forums/show-tell-gallery/54328-boxsterls376-introduction-ls3-conversion.html
