Old 12-10-2015, 09:18 AM   #2
JayG
On the slippery slope
JayG's Avatar
in relation to factory tire and wheel sizes
on the fronts, the tire is 9mm closer and wheel will be 4mm closer to the suspension. Spacers may be needed.
on the rear, the tire and wheel will be 7 mm farther away, so no spacer needed and will still probably be under the fender
Mount them and see if there is a clearance problem on the front. If so, add a spacer
2004 996 Targa Tip
Instructor - San Diego region
