Old 12-09-2015, 06:53 AM   #13
JayG
On the slippery slope
JayG's Avatar
Originally Posted by BH2000S View Post
Thanks for all the great advice. I have not had time to jack the car up and check the water pump yet. I did check the burp valve (aka coolant bleeder valve?), totally clean. The expansion tank cap seems to seal fine but the threads seem a little wonky and the part number ends in 02 so I'll order the $27 updated Porsche one from Pelican. I don't really smell anything in the trunk.
I don't know if the water pump was replaced with the engine. The receipt notes a lot of hours cleaning coolant out of the oil system but not the water pump. I need to track down more info from a dealer.
If it is a small seal leak, I would be tempted to use a cooling system sealer but I'm guessing that will just cause problems down the road with a Porsche.
Do not under any circumstances use cooling system sealer. That stuff can clog up places you don't want restricted.
If you do use it, please post your VIN so we know to avoid your car if you sell it
2004 996 Targa Tip
Instructor - San Diego region
