Yes, it's likely one has to travel to obtain the right Boxster ... in my case to a Ford dealer in Brighton, Colorado.
Learned about the headlight switch on the drive home as when I one time switched from high back to low beam I got darkness instead.
As regards your clutch (you may already know this) this car has a dual-mass flywheel which could require replacement at the same time. A $1000 part itself.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
