Thread: 2002 Mirror
Old 11-30-2015, 09:15 AM   #2
lkchris
lkchris's Avatar
It's on my list of to do projects.
It will be very expensive.
Buying new parts from Porsche ...
The interior mirror is around $400
The side mirror glass is around $350
The wire harness for the interior mirror is $35
The wire harness inside the exterior mirror is $35
Porsche says and I agree you need a complete new left door interior wire harness $350
Have been watching eBay and it appears this was a very rarely fitted option and used parts seldom appear
I was extremely lucky I think when I purchased a pair of door wiring harnesses from eBay for $16 thinking I'd cannibalize them for parts to modify mine. Turns out the left one I received is the new "everything" harness with all the wires needed ... meaning auto dimming mirror and memory mirror as well as the usual mirror heat and adjustment. Maybe it's a good thing to check if I (and you) already have this harness installed.
Most eBay dismantlers seem savvy to this and will show the connector on any door mirror offered for sale. Most typically they have 5 connectors, meaning just heat and adjustment. The memory seats/mirror option is more common and some will show more connectors when that was fitted ... but you need all connectors to achieve auto dim. The $35 harness with everything seems the way to go.
There may be an Audi part number for the interior mirror.
There is a TSB for retrofitting this system where you
Fit the new interior mirror
Run wiring harness across windshield moldings and down to relay box and to door harness connector and under drivers seat to obtain reverse gear signal.
Replace complete door wire harness
Replace door mirror components
The OE system includes reverse gear sensing to provide undimmed mirror any time car is in reverse. Of course you don't have to fit the auto dimmable door mirror and can just stop with the interior mirror. The door mirror gets the signal to auto dim from the interior mirror, hence the wiring through the bellows connection in the door.
Rain sensing is another topic altogether and I haven't studied it in any depth. There's likely a retrofit TSB as well.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
