Everything being equal and you have installed the rear strut correctly (and there's not a lot to get wrong on installation) the only other part than affect ride height is spring length. Did you measure old vs new struts?
Remember that if you removed / loosened the lower control arm connecting the hub to the chassis, the control arm must be loaded (weight of car sitting on its wheels) before tightening the retaining bolts.
2001 MV Agusta F4.
