Old 11-28-2015, 11:56 AM   #13
jim_hoyland
jim_hoyland's Avatar
Originally Posted by jaykay View Post
It will be a while before I can get to it.....spring as the car is all stored up. Not sure you would want to wait that long! It sounds like a real pain and am dreading it! Are the instructions wrong such that you cannot determine the right terminals?
The dude sent me an old crusty switch...which I have been trying to get replaced...no luck so far. I believe it is a just defroster switch with a sticker on it
I read over the instruction several times, but ended up having my mechanic do the installation. It works fine; one of the wires got into the wrong slot and I believe it is the green wire.
Note:The two pins on the green wire are a real PITA; he installed two other connecting pins to replace them. I'll get the part name/number from him next week.
Doesn't matter at this point when I fix the flashing; just want someone who' scoring the install or working in that area to verify which wire/slot is hot when the spoiler is in operation. That would be the wir/slot I have wrong.
jim_hoyland is offline   Reply With Quote
