Originally Posted by jim_hoyland
Probably will be OK. Would you help me out when you do the installation ? After inserting the wires into the gauge cluster blocks, raise or lower the the spoiler and determine which wire transmits the flashing. Then I'll know which one of mine is in the wrong slot.
It will be a while before I can get to it.....spring as the car is all stored up. Not sure you would want to wait that long! It sounds like a real pain and am dreading it! Are the instructions wrong such that you cannot determine the right terminals?
The dude sent me an old crusty switch...which I have been trying to get replaced...no luck so far. I believe it is a just defroster switch with a sticker on it
