Thread: Aos change out
Old 11-27-2015, 02:50 PM   #2
cas951
One of the hardest part to remove is the clamp on the flexible hose. Most that gave done it have been frustrated by it. This is what I did and made the job much easier.
Take a look at the new AOS. It usually comes with a new flex hose. I've done two if these and both times it came with a new flex hose. Go u dear the car with a sharp knife and cut the flex hose but be careful not to cut anything else. When re-installing I used standard clamps that you can use a socket to loosen or tighten.
You will save a lot of time doing it this way.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
