Old 11-24-2015, 06:04 PM   #2197
Sassmatt72
Exclamation Sacrilege... I gained foot room...ask me how
Danger, Sacrilege and advanced modification ahead.
So I rotated the fuse box up to the lip the OBDI-II port is on...
I hope my fuses don't fall out now it's facing down.
so.
moved the port elsewhere. used it's hole towards the middle and drilled a second 3" towards middle, re-used it's screws into two holes the carpeted cover screwed into, cut a bit of the ziptie channel off...
Had to massage the air duct a bit to squeez the box up there, but it's soft plastic.
took a bit to gently and slowly flex the wiring loom into the new position
(removed old wrapping, & combed it w/ my fingers)
easier w a heat gun I'd think (but carefully) on duct.
them trim down side cover to a sliver to protect the loom from your foot on entry.
To do it again, I'd heat the wiring loom a bit too when flexing it into new location.
then wrap in tape.
now a totally hidden fuse box, and tons more foot space.
Sassmatt72 is offline   Reply With Quote
