You need to have a back up car. If this is to be your sole means of transportation, not a good idea. These cars can stop working for some pretty small stuff, for that matter, any car 18 years old can.
The parts that time kills will need some preventive replacement, Water pump, Expansion tank, AOS, fluids
At 37k the wear items are probably in good shape. This car most likely has the Dual Row IMSB, that's a good thing
As mentioned, these cars run better when they are driven regularly, and stressed from time to time
Oh and you may want to check out those radiators - It appears they are leaking pretty bad
At least you don't have to move the steering from the wrong side to the left side
Seal Grey
