Old 11-23-2015, 10:26 AM   #11
911monty
911monty's Avatar
Originally Posted by boxxster View Post
Alright so I tried to look around a bit under the car thinking that maybe I would find something wrong with the cylinder 3 coil or injector and I found this random loose hose with a bit of wetness at the end. For reference, thats the axle in the foreground and I was looking from the rear of the car. The first pic is sideways, it should be 90 degrees to the right so the hose points downward. The second pic is looking straight up at it from underneath the axle area.
Any ideas? I know when I was running the coolant in when it overflowed it drained out onto the floor in this general area. But if this is just trunk drain for the coolant and oil adding area I don't see why it would have a hose clamp on the end of it. Any ideas?
Looks like tank fill area drain hose to me. Pour some water into the fill area with someone watching or plug with pencil then pull. As far as hose clamp.......ask PO?
