Old 11-22-2015, 10:35 AM   #380
ianacole
Currently, I am not using either of those. I do plan to install the TechnoSump (2 qt deep sump with horizontal tray) over Thanksgiving.
Thanks. If you don't mind, let me know how it goes. I've been evaluating the engine cooling options out there and have not been able to find a definitive answer ... probably user dependent
  • I've heard the S cooler only provides marginal cooling improvements
  • With an accusump type setup, I've heard that an oil leak will result in the entire system purging itself
  • External setups can be complicated and expensive, and cooler location can expose it to damage
Wish there was just an easy, straight-forward, proven solution
ianacole is offline   Reply With Quote
