Old 11-18-2015, 05:41 PM   #15
JayG
On the slippery slope
JayG's Avatar
Originally Posted by xzl6b1 View Post
Had a misfire, that progressively got worse. O'Reilly auto parts used a Bosch scan tool, and found that the #6 coil was bad.
I removed all 6 coils. all coils were within spec (pin 1-3 resistance primary winding).
Replaced #6 with a Beru to correct the misfire.
If a scan tool is not available, the best test is to remove the allen screws that secure each coil, engine running, pull each coil out and listen for a change in engine speed/sound. Replace the coil and repeat for the remaining coils to determine the bad coil(s).
This tests both the primary and secondary windings.
Uh, unless I am missing something, pulling the coil will result in that spark plug not firing
2004 996 Targa Tip
Instructor - San Diego region
