Old 11-18-2015, 02:12 PM   #9
lkchris
lkchris's Avatar
The temperature rating of a replacement thermostat must be the correct one for the application because of the adverse affects the wrong thermostat can have on drivability, engine performance and emissions.
The temperature rating specified by the car manufacturer is especially important in many 1981 and newer vehicles because the onboard computer monitors coolant temperature through a coolant sensor to control fuel enrichment, spark timing and operation of the EGR valve. Even on vehicles without computers, thermal vacuum switches that react to a specific coolant temperature are often used to open and close various vacuum circuits that regulate fuel enrichment, timing and EGR. If a colder thermostat is installed, the coolant may never get hot enough to trigger the appropriate control functions or to allow a computer system to go into “closed loop”. Too hot a thermostat can also interfere with the proper operation of engine controls, and increase the engine’s operating temperature to the point where it may experience detonation (spark knock).
http://www.crankshaftcoalition.com/wiki/Thermostats_explained
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
lkchris is online now   Reply With Quote
