Old 11-16-2015, 06:37 AM   #10
CraigM
Concerning the sway bar -
I bought a 2002 Boxster S M030 front sway, which also has a green dot. I was hoping the mounting hardware would be different and lead to some clues, but it appears to be the same for non-M030.
I did find this on renntech, courtesy of Topless a few years ago:
(996-343-701-23 vs -21)
21= Base M030 (*and S non-M030 per Pelican parts*) 23.6mm 3.5mm
23= Box S M030 24.0mm 3.8mm
So it should be very slightly thicker, or maybe you'll see a slight weight difference if you have a very accurate scale...
CraigM is offline   Reply With Quote
