Old 11-16-2015, 04:15 AM   #1
jcslocum
Project Addicted
jcslocum's Avatar
OK, here is what I did.
I cut the harness from my existing seat that plugs into the car wiring harness. It's a big black flat plug that also has the seatbelt plug in it. I then wired it and made some jumpers up to connect it to the #6 plug location on the seat.
It gets wired like this:
This drawing is flipped from the plug orientation above.
#1 large is a 12v from the harness.
#2 Large is a ground from the wiring harness.
Now the small pins
#1 is 12 volts jumped from large #1 above ( my pic doesn't show it.)
#2 you will need to run from the fuse box to supply a switched 12V to this pin
#3 is a ground that is jumped from large #2 above.
The large #1 and #2 are regular spade plugs that get crimped on.
#1 - #3 small pins, I used the red barrel or butt connector crimp on and gave them a squeeze until they fit snug on the pin. I trimmed off the excess insulation on one end and crimped it to the wire on the other end.
Works like a charm!!
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
