Old 11-12-2015, 11:22 PM   #2
stelan
stelan's Avatar
Misfires are typically electrical or timing related. Re-check the electrical connections that were disconnected/re-connected. Are you sure that nothing else electrical was disconnected or knocked loose (like a wire from the flywheel sensor or cam position sensor or something similar to that)?
Thanks, It is possible that I knocked sothing loose when I was working on it as snaking that ps line is a pita, where are the connectors for the cps or fs? Would the obd2 reader detect those being unpluged?
stelan is offline   Reply With Quote
