Old 11-12-2015, 11:58 AM   #30
JayG
On the slippery slope
JayG's Avatar
maybe this will clear it up
in order for the alarm to arm, all door closed, frunk closed and latched, trunk closed and latched, glove box closed and latched, center console closed and latched and the top up and latched. the center console and glove box do not need to be locked
if you click the remote 1 time, it will lock the car and arm the alarm. The parking lights flash twice, no horn beep
if the top is down, the same, but it will not arm the alarm
If anything above is not latched, 1 click will lock the car, but not arm the alarm and in addition to the double parking light flash, the horn will beep
If you double click, it will lock the car and not arm the alarm. You get double light flash and a horn beep
If the top is down and you have the red clip (or a penny) inserted, it fools the system to think the top is up and latched and will arm the alarm assuming everything is latched.
You can also fool the system by pushing the microswitch in the top latch and hold it there until the windows come up and then turn off the car. You can then remove your finger
All of this except for the red clip/penny/finger is in the manual
Capisce ?
as far as your old dog being deaf, well it sounds like he has has a good life
2004 996 Targa Tip
Instructor - San Diego region
