Originally Posted by Swhitcomb
What does this do for you? I read last night bending pin 18 makes the top operate while moving as long as the ebrake is up enough to illuminate the light. What does pin 15 do?
if you bend pin 15 and ground the top relay internally by soldering a wire you wont need to pull the handbreak at all.
