Old 11-12-2015, 06:48 AM   #15
klab
Thanks for tips. My concern is that ignition switch itself is OK, but signal from gearbox is NOK. By this I mean that ignition switch doesn't know that I put gearbox to parking ant this is the reason that I can't take out the key.
Doe's anyone know how to verify signal coming to the ignition switch? On the instrument I see that it is changing into P, but I am expecting signal wire from gearbox to the ignition switch to be the issue.
I will replace switch anyway.
I want to check signal before. Maybe any picture with descr. which cable to check with multimeter?
Thanks in advance.
Kris
klab is offline   Reply With Quote
