Old 05-27-2006, 11:16 PM   #11
MNBoxster
Originally Posted by xclusivecar
What if you just removed the oil filter and dumped out its contents. Not sure how much oil will come out if you do this...but many Boxster owners only do full oil changes 1 or 2 times per year depending on mileage. In between these full oil changes they will change only the oil filter. It may get a little bit messy but oil won't just "stream" out of there, will it?
Hi,
As I understand it, the Filter takes about 0.75 Qts. with it. No, if you open the cannister, only the Oil in it and the Filter will be removed from the system - 0.75 Qts...
Happy Motoring!... Jim'99
