Old 11-12-2015, 04:24 AM   #13
GatorLapis
I am currently running Sumi HTR ZIII
225 f / 255 r in 17"
cold they are 31/33
Since racer boy agrees with your viewpoint I would try it on the next autox. Keep the rear at 37 and keep raising the tire pressure on the front as much as you can so you get full contact patch surface area. You can use a chalk or paint and mark the sides of the tire. If you feel more under steer keep your front at 33/34 and raise your rear as much as you can to keep your full contact patch area. Post back with results.
GatorLapis is offline   Reply With Quote
