Old 11-11-2015, 08:39 PM   #10
Dr Feelgood
Originally Posted by der Geist View Post
I had a bumper like the precision911 one on my Boxster. I'm probably going to selling it if you are interested. Everything went fine on the install, it mounts with the same screws for the most part. I had to drill holes for the screws inside the turn signal housings but that's about it as far as I can recall. I just removed the headlight assemblies, installed the bumper and re-installed the headlight assemblies, no problems at all.
The 997 conversion is really expensive and if you are switching headlights add at least $1000.00 to the cost for the headlights alone.
Pretty expensive upgrade if you are not doing the work yourself.
Does your bumper have the additional turn lights on it or is it the one from NR that has it deleted? Yes I do know that the headlights are expensive and that is one of the thing keeping me from that particular bumper at the moment.
Dr Feelgood is offline   Reply With Quote
