Old 05-27-2006, 03:33 PM   #2
denverpete
Originally Posted by BrianD.
Hi guys -
I have a 2kS 6spd. Sachs clutch, Advanced Flow Engineering intake conversion. When I step (hard) on the gas, the engine chokes and sometimes pops back through the intake. For example, if I want to pull out of a driveway ahead of approaching traffic, it means I have to get the revs up first, then ease out the clutch. Once I'm moving out, I'm OK.
What's causing this choke problem?
BD.
Sounds like a clutch issue. Is this a new problem occuring long after your mods or have you had some work done that might give a clue? If you put in your clutch coming up to a stop at high revs does it want to die (kind of the reverse of your problem)? If so, I'd definately say clutch.
I'm sure you'll get more info from others on the board. Probably so much info that you'll actually hemorage from your eyes. Just remember, no matter what they say, I invented bubble wrap. Keep that in mind. I'm serious...
'06 Cayenne Turbo S, Beige Metallic/Tan
Ex - '99 Arctic Silver, Red Interior, Silver Top
denverpete is offline   Reply With Quote
