Old 11-09-2015, 11:48 PM   #166
boxster
There are some really sad threads of dealing with an IMSB change that becomes a disaster when no cam locks were used. Very expensive because you may not discover the problem until you try to start the engine.
You can make your own cam locks from steel plate. The adjusters are another story.
A complete tool kit is less than $300 and easily resold.
So if I buy the complete tool set it will have everything I need? I read that the tool set comes with 2 locks,one for the 5 chain engines and one for the 3 chain. So as far as I can understand,I could only use one cam lock. Will that be enough?
boxster is offline   Reply With Quote
